MODE.SNGL function
MODE.SNGL() function
Star InactiveStar InactiveStar InactiveStar InactiveStar Inactive
Return the most common value in a data set
=MODE.SNGL(number1, [number2], ...)
MODE.SNGL function replaces the prior MODE function.
Return the most common (frequently occurring, repetitive) value in a numeric data set using either defined values (e.g. 1,1,2,3) or ranges, named ranges or cell references (e.g. C3:C6).
MODE.SNGL syntax requires the number arguments to be considered.
MODE.SNGL with a number.
In the example below, the MODE.SNGL function is used to identify the most frequently occurring numbers in a list of defined values or a cell range.
Use the MODE.SNGL function to return the most common value in a data set.
Use the Excel function MODE.SNGL to return the most common value in a data set.
The MODE.SNGL function consists of at least 1 argument:
  1. number 1. Required. A number or cell reference that refers to numeric values.
  2. number 2. Optional. A number or cell reference that refers to numeric values.
  • Enter your formulas into the grey cells.
MODE.SNGL can be applied to numbers, ranges, named ranges or cell references. Up to 255 numbers can be supplied as separate arguments.
  • Number:
  =MODE.SNGL(1,2,3,1) || result is 1
  • Cell reference:
  =MODE.SNGL(C3:C10) where the range holds values in each cell
  • MODE.SNGL will return #N/A if there are no duplicate values to be found
  • Empty cells, and cells that contain boolean values or text will be ignored by the MODE.SNGL function. Cells with the value zero (0) will be included.
  • AVERAGE() returns the average (arithmetic mean) of the values in a data set.
  • MEDIAN() returns the median (middle number) of the values in a data set.
  • MODE.MULT() returns the most common values in a data set as an array.
  • MODE() returns the most common value in a data set. Use MOMODE.SNGL instead.
Register (for free!) or Login to access bonus materials
About xlsnippets
Learn how to master functions, charts, pivot tables and more using Excel for Microsoft Office 365. Simple instructions and embedded spreadsheets help you practise the basics.
Latest Updates
26 March 2022
26 March 2022
26 March 2022
25 March 2022
22 March 2022
Coming soon
xlsnippets.com is currently in beta version. More functions and bonus content for registered users will be added weekly. Detailed training courses with additional downloadable resources are also on the horizon!
