Returns a vertical array of the most common values in a data set.
=MODE.MULT(number1, [number2], ...)
Return the most common (frequently occurring, repetitive) values in a numeric data set using either defined values (e.g. 1,1,2,3) or ranges, named ranges or cell references (e.g. C3:C6). If there are multiple modes, more than 1 result will be returned.
MODE.MULT syntax requires the number arguments to be considered.
MODE.MULT with a number.
In the example below, the MODE.MULT function is used to identify the most frequently occurring numbers in a list of defined values or a cell range.
Use the MODE.MULT function to return the most common values in a data set.
=MODE.MULT (number1, [number2], ...)
The MODE.MULT function consists of at least 1 argument:
- number 1. Required. A number or cell reference that refers to numeric values.
- number 2. Optional. A number or cell reference that refers to numeric values.
MODE.MULT can be applied to numbers, ranges, named ranges or cell references. Up to 255 numbers can be supplied as separate arguments.
=MODE.MULT(1,2,3,1,2) || result is an array of 1,2 |
=MODE.MULT(C3:C10) where the range holds values in each cell |
- Arguments can be numbers, defined names, arrays, or cell references that contain numbers.
- Empty cells, and cells that contain boolean values or text will be ignored by the MODE.MULT function. Cells with the value zero (0) will be included.
- MODE.MULT will return #N/A if there are no duplicate values to be found
- The MODE.MULT function must be entered as an array formula (CTRL+SHIFT+ENTER) in versions of Excel other than Microsoft 365.
- For horizontal arrays, use the TRANSPOSE function along with MODE.MULT
- AVERAGE() returns the average (arithmetic mean) of the values in a data set.
- MEDIAN() returns the median (middle number) of the values in a data set.
- MODE.SNGL() returns the most common value in a data set.
- MODE() returns the most common value in a data set. Use MOMODE.SNGL instead.
