Returns the median or middle number in a data set.
=MEDIAN(number1, [number2], ...)
Return the median or number in the middle of a set of numbers using either defined values (e.g. 1,1,2,3) or ranges, named ranges or cell references (e.g. C3:C6).
MEDIAN syntax requires the number arguments to be considered.
MEDIAN with a number.
In the example below, the MEDIAN function is used to identify the median or middle number in a list of defined values or a cell range.
Use the MEDIAN function to return the median or middle value in a data set.
The MEDIAN function consists of at least 1 argument:
- number 1. Required. A number or cell reference that refers to numeric values.
- number 2. Optional. A number or cell reference that refers to numeric values.
MEDIAN can be applied to numbers, ranges, named ranges or cell references. Up to 255 numbers can be used as separate arguments.
=MEDIAN(1,2,3,4,5) || result is 3 |
=MEDIAN(C3:C10) where the range holds values in each cell. |
- If there is an odd number of values, the middle number is returned.
- If there is an even number of values, the median is calculated as the average of the two numbers in the middle.
- Arguments can be numbers, defined names, arrays, or cell references that contain numbers.
- Empty cells, and cells that contain boolean values or text will be ignored by the MEDIAN function. Cells with the value zero (0) will be included.
- MEDIAN will return #N/A if there are error values or text that can not be interpreted as a number in the arguments.
- AVERAGE() returns the average (arithmetic mean) of the values in a data set.
- MODE.MULT() returns the most common values in a data set as an array.
- MODE.SNGL() returns the most common value in a data set.
- MODE() returns the most common value in a data set. Use MOMODE.SNGL instead.
