Return the logical value TRUE if the cell contains any value that is not text.
=ISNONTEXT(value)
Return the logical value TRUE if the cell contains any value that is not text, including numbers, dates, times, errors, formulas that return non-text results and an empty cell.
ISNONTEXT is part of the collective IS functions which check specified values and return TRUE or FALSE depending on the outcome. The IS functions are useful for testing the outcome of a calculation and can be combined with the IF function in formulas to locate errors or get information about a value before performing another calculation.
The collective of IS functions are ISBLANK(value), ISERR(value), ISERROR(value), ISLOGICAL(value), ISNA(value), ISNONTEXT(value), ISNUMBER(value), ISREF(value) and ISTEXT(value).
To test the reverse of the function (e.g. to test if a cell does NOT contain an error), combine the ISNONTEXT and NOT functions - =NOT(ISNONTEXT(C7)) where cell reference C7 is the value being tested.
ISNONTEXT syntax requires a value to test. The value argument can be a blank (empty) cell, error, logical value, text, number, reference value, or a name referring to any of these.
ISNONTEXT with text strings or numerical values.
In the examples below, the ISNONTEXT function is used to determine whether cells contain text or not.
Use the ISNONTEXT function to return the logical value TRUE if a cell contains any value that is not text.
ISNONTEXT(value)
The ISNONTEXT function requires 1 value argument:
- value. Required. Generally a cell reference.
- Select the answer from the drop down lists in the grey cells.
ISNONTEXT can be used on its own to determine whether a cell contains a TRUE or FALSE statement or combined within a formula to test a value prior to performing additional operations.
=ISNONTEXT(1/0) || result is TRUE as divide by zero triggers a #DIV/0! error not a text statement. |
=ISNONTEXT(C7) || result is FALSE if cell reference C7 contains text. |
=IF(ISNONTEXT(C7),"Cell does not contain text","Cell contains text") || when ISNONTEXT is TRUE, the result is "Cell does not contains text", otherwise it is "Cell contains text" |
- Values that have been concatenated using the ampersand (&) are represented as text so will return a FALSE statement to the ISNONTEXT function.
- Value arguments are not converted. Numeric values enclosed in double quotation marks are treated as text (e.g. "22"). Any IS functions requiring numeric values will therefore return a FALSE if the value is a text string.
