Return the logical value TRUE if a cell is blank or empty
=ISBLANK(value)
Return the logical value TRUE if a cell is blank or empty and FALSE if the cell contains content (even if not visible).
ISBLANK is part of the collective IS functions which check specified values and return TRUE or FALSE depending on the outcome. The IS functions are useful for testing the outcome of a calculation and can be combined with the IF function in formulas to locate errors or get information about a value before performing another calculation.
The collective of IS functions are ISBLANK(value), ISERR(value), ISERROR(value), ISLOGICAL(value), ISNA(value), ISNONTEXT(value), ISNUMBER(value), ISREF(value) and ISTEXT(value).
To test the reverse of the function (e.g. to test if a cell is NOT blank), combine the ISBLANK and NOT functions - =NOT(ISBLANK(C7)) where cell reference C7 is the value being tested.
ISBLANK syntax requires a value to test. The value argument can be a blank (empty) cell, error, logical value, text, number, reference value, or a name referring to any of these.
ISBLANK with text strings or numerical values.
In the examples below, the ISBLANK function is used to determine whether cells are empty or blank.
Use the ISBLANK function to return the logical value TRUE if a cell is blank or empty.
ISBLANK(value)
The ISBLANK function requires 1 value argument:
- value. Required. Generally a cell reference.
ISBLANK can be used on its own to determine whether a cell is empty or blank or combined within a formula to test a value prior to performing additional operations.
=ISBLANK("Not Blank") || result is FALSE as cell value is Not Blank |
=ISBLANK(22) || result is FALSE as cell value is 22 |
=ISBLANK(07/02/2022) || result is FALSE as cell value is the date 07/02/2022 |
=ISBLANK(C7) || result is FALSE as cell reference C7 contains a space |
=ISBLANK(C7) || result is FALSE as cell reference C7 contains a formula (e.g. =IF(C7+C8>10,"",C7+C8) will return what looks like a blank or empty cell if the contents of C7+C8 are greater than 10 whereas in reality the cell contains a formula). |
- Value arguments are not converted. Numeric values enclosed in double quotation marks are treated as text (e.g. "22"). Any IS functions requiring numeric values will therefore return a FALSE if the value is a text string.
- ISBLANK will return FALSE even if the cell contains an empty string (i.e. C7="", with no spaces). =C7="" and =LEN(C7)=0 which both return TRUE are alternative approaches for identifying cells which contain empty strings.
